philip67's avatar
philip67
12 months ago
Volt Gig1 Speed
hi for those of you wondering why your not seeing 1130 + Mbps
with your Gig1 volt connection when you speed test online to check!it,the main reason your only seeing 940 Mbps is because you only have a 1 Gb Adapter in the computer, so now that you know this Fact' go Buy a 2.5 Gb Adapter with this you'll see the full speed router = 1144 Mbps and to device your pc download will be 1130 to 1235 Mbps on good days when SamKnows is running under less load'
ok back to the Adapter these are the settings i have mine set too,and my download is at the time of writing this, 1138 to Router @ 1165 to Device time is 00:16 now you can run the test a few times and speed will vary that's down to the Congestion and load on there servers, any how set your 2.5 Adapter to these settings of mine and see if yours works as fast,just copy the original settings in case you need to change back!
okay
disabe All Offloads
Flow Control auto negotiation
Jumbo Packet = 9014
Packet Prioity & VLAN disabled
Receive Buffers = 2048
Selective Suspend disable
Selective Suspend idle Timeout = 5
Speed & Duplex 2.5 Gbps Full Duplex
Transmit Buffers = 2048
------------------------------------- that should get you the best speed hope this Helps
regards Philip67
No RepliesBe the first to reply
