JD69's avatar
JD69
3 days ago
hisense e7q pro 43" qled 4k hdr smart tv
Hi.
Trying to find the code to pair V6 remote with the above TV.
Tried the suggested codes and 0999 and volume up/down scrolling but with no luck.
Anyone paired to this tv and know the code?
Or can it not be done.
Thanks.
1 Reply
  • goodbodyj's avatar
    goodbodyj
    Hmm I have the non-PRO version.  Trying to remember how I got it working...
    I think I used the 0999 method BUT importantly I turned off bluetooth on the TV, I think the default is that it looks for a bluetooth remote signal by default, which the Virgin remote won't send.  If that's not clear let me know and I'll try to find the precise setting.
