falcon2's avatar
falcon2
24 hours ago
VM Source problem on TV
Yesterday the TV and 360 Box turned off unexpectedly. I did the usual unplugging etc and eventually things came back but not for long. For the next hour one or other or both devices were switching themselves on and off. I checked the service status on VM and it turns out that there was an intermittent fault in the area. Give it 24 hours. Today, the TV and Box are working but there is an orange colour on the service status for the TV.
The Samsung remote doesn't now work the TV apart from showing the source. The VM remote operates TV and Box but there's no source button. The VM icon has completely disappeared from the TV and the source shows as Skytv. Should I be bothered by this, surely the source should be VM?
The HDMI cable is connected to the normal port, not the ARC3? one, is that correct? When I was reconnecting everything yesterday I did go to the ARC3 one and no internet was forthcoming so I guess it's now in the right one. All settings show as OK on VM ( apart from TV ).
If you're still reading this, you can see that I'm hopeless with technology! I'm reluctant to use the chat facility at this stage as I put myself under pressure and start pressing the wrong buttons. Therefore, any simple steps advice would be gratefully appreciated Thanks.
  • Roger_Gooner's avatar
    Roger_Gooner
    Do you have a Sky box? I'd expect the 360 to be connected to HDMI 1 and Sky to HDMI 2, and you select the correct source with your TV remote. If this remote is playing up, change the batteries.
    The source button on the TV360 remote is in the bottom right hand corner (TV input) , just below the number 9 button, as per the screenshot shown below.
    The linked thread <Here> might help with the TV set source showing as Skytv.
  • japitts's avatar
    japitts
    On what basis is your TV labelling certain inputs as "VM", "Sky" or whatever else? I would expect it to have "HDMI-1", "HDMI-2" and so on - and then somewhere in your TV menu settings, should be an option to choose "1" for HDMI-1, "2" for HDMI-2 and so on.
    Whatever an input is physically labelled as, on the back of your TV, should correlate to an input on the menus.
