BlueMyrtle's avatar
BlueMyrtle
3 hours ago
VM 360 box problems
On Saturday 14th Sept we tried to upgrade our V6 box to the VM 360.  It seemed to work fine, except for the BBCi and ITVX, when we got blank screens (tried it several times).   We made sure the HDMI cables etc were secure, and the TV set to HDMI
  Following instructions online we tried the following:
  1. rebooting the box - this resulted in not being able to access anything on the TV at all, completely blank screens
  2. forced reboot: we tried turning off the box and tv, and turning on whilst simultaneously pressing the minus and power buttons on the V6/360 box.  Some download button appeared on tv but then resorted back to the Welcome page.  the box itself keeps making whirring noises though.
  3. we cannot access anything on the TV whatsoever.
  4. tried again this morning without any success
So now we are without a TV.  Please help!
    Try turning off the 360 by the switch on the back of the box;  then on the front of the 360 box  hold down both the standby/power button and the - (minus) button at the same time. Then turn on the 360 again whilst keeping hold of those buttons for a further 30 seconds.
    If the standby/power button and the -  button workaround doesn't solve it then try using the standby/power button and the + (plus) button at the same time instead.
    You could also try the three fingered salute, which is switch off on the back of the box;  then on the front hold down the plus, minus and standby/power buttons at the same time, and switch on again whilst keeping all three buttons pressed down.  When it restarts you might see a message it can't acquire the channels. If so press OK and let it restart again.
    • BlueMyrtle's avatar
      BlueMyrtle
      thanks - I've tried the forced reboot with both plus and minus options.  I'll try the three fingered version.   Sent husband off for a new HDMI cable too but it was working perfectly fine before the 360 upgrade.
        BlueMyrtle
        So the "three fingered salute" didn't work.  Also changed the HDMI cable - that didn't work either.
      BlueMyrtle
      I can't do a factory reset without being able to access information on the TV screen. I've done a forced reboot only
