panostar's avatar
panostar
6 months ago
Problem with optical connection to HiFi audio
Today I converted my V6 box to TV 360  and while it is generally working ok, I'm getting no audio through an optical connection to my amplifier for most channels, but just a few work fine.  e.g  channels 103 and 601  have sound but very few, if any, of the other channels have sound working.  I used exactly the same connections when the box was operating in it's V6 guise and never had any such problems.  Any ideas what's causing this and any solution?
  • I tried switching everything off and back on and that made no difference.  However, your second suggestion has been more effective.  I changed the Audio setting to pcm 2.0 and that has solved the problem.  Many thanks!
  • Hello panostar,
    Welcome to the Community, and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re experiencing with your TV at the moment. Have you been able to get the sound restored with the advice from newapllo, or do you need further assistance?
    Kind Regards,
    Steven_L
    Hi panostar​
    Have you tried rebooting the TV, 360 and amplifier?
    Also on the 360 go to Settings > Audio & Video > Audio output  and try the three different settings.
    • panostar's avatar
      panostar
