Beemer's avatar
Beemer
Superfast
365 box problem
When I go to my 365 recordings and select 'all'  my remote will not allow me to scroll anywhere neither up or down.  If I don't select 'all' I can scroll to any recording picture.  I have another 365 box which is working normally.
I have tried recycling the box but it still has the problem.  How can I fix this
  • If you have tried rebooting the box by turning the power off and on with either the switch on the back of the box or at the plug, this has worked for some people, you can also try pressing the 'TV' and '0' buttons for 10 seconds and it should now repair the remote.
    If that doesn't work you could try a factory reset which works for me when this happened with my remote.
    It's only a partial system reset and not a complete factory reset. You are given 2 options,
    Keep Recordings
    Format Disk
    Choose Keep Recordings, that means you won't lose your recordings and any planned recordings or series links you've set up, you will have to sign into your apps such as iPlayer, Prime, Netflix and ITVX again, also Match frame rate and Standby power consumption will go back to their default settings if you have changed them.
    Keep Recordings
    Format Disk
    • Beemer's avatar
      Beemer
      Superfast
      Roy, your second suggestion worked.  thanks, Ian
  • Sabrina_B's avatar
    Sabrina_B
    Hi Beemer 👋.
    Thanks for reaching out to us, sorry to hear that you are having issues with the remote selection process when selecting recordings. Can we ask, since your post are you still having the same issues or are you in need of assistance?
    Please let us know.
    • Beemer's avatar
      Beemer
      Superfast
      all now fixed after reset, thanks, Ian
