kuberr's avatar
kuberr
WiFi coverage not great, need help
Joined up to 1 gig package a few days ago and getting around 800mbs in the room of the hub and around 500 one floor up.
My previous extender I used with sky isn't improving the coverage at all, it's dual band but the virgin connect app suggests turning this off as its best to use a single band only.
What's best in this scenario? What device can I use to extend the signal but only the 5g? I dont want to create a second network name.
    Reads like you have not configured your Wi-Fi Repeater correctly or it is placed too far from the VM Hub
    i.e. in a location where the VM Hub's Wi-Fi signal is far too poor to repeat.
    The comment about the VM Connect app not quite correct.
    The Connect app is trying to merge the Hub's 2.4 & 5 GHz SSIDs into a common network.
    If you wish to have split SSIDs, start by uninstalling the Connect app from all devices in your home
    and manage the Wi-Fi via the Hub menu at http://192.168.0.1/
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there kuberr
    I am so sorry that you are facing an issue with your booster and connection, I've been unable to locate your account via your details so I'm going to pop you a private message so we can take a closer look.
  • jb66's avatar
    jb66
    I think your wifi expectations are unrealistic, 500mb one floor up is really good
