Chromedome73's avatar
Chromedome73
Upgraded to M600 - speed
Hi, just renewed my M250 package to M500.
I was getting good constant speeds on M250 but now since I've upgraged/Renewed it seems to be pretty poor in comparison .
I use Fast.com on my phone & it gets to about 140 Mbps where as before I was hitting approx 230 Mbps.
I also use it in router mode with a Deco M5 Mesh system
Is there anything i need to do or reset etc?
Cheers for any info
[Mod - title edited for clarity]
  • If you are using the HUB in router mode use the below link to check the speed to the HUB over the VM network:
    https://samknows.com/realspeed/
  • Hi, so obviously I made a few mistakes in my first post.
    Tile Should be M500 not M600
    I am indeed in Modem Mode
    I need a  USB Ethernet adapter to test,as I use a Chromebook
    Think Broadband quality checker is showing just a red block? (Dropped packets 100%)
      We use HP USB 3 to Gigabit network adaptors they are £10 from eBay,
      for slim laptops they are exactly like having an inbuilt network socket.
      Verify the BQM points to the current Public IP of your connection.
      If the IP is correct, in the firewall settings of the Deco M5 Mesh
      make sure it is configured to respond to pings from the WAN.
    • Matthew_ML's avatar
      Matthew_ML
      Hey Chromedome73, thank you for reaching out and a warm welcome to the community, I am so sorry to hear about your speed issues.
      I've taken a look and everything is looking great from our side, how has it been over the weekend?
  • https://www.thinkbroadband.com/broadband/monitoring/quality/share/b82cc91a041d09031e8f5ca0fa2d38484b18b44f-03-03-2025
    This is my graph for the last few days (i hope its worked right)
    • Gareth_L's avatar
      Gareth_L
      Hello again Chromedome73.
      Would you be able to remove your Mesh system and run a speed test through this link please
      Gareth_L
