nigelrjf's avatar
nigelrjf
8 months ago
Still an area problem in N2
Hi Forum team. In a previous post I reported that a VM network engineer appeared to track down the main cause of the area outages to excessive upstream noise, and had replaced various components in the street cabinets on 8 August (power supply, amplifier and splitters I believe). Since then, we don't appear to have suffered any complete outages, but we are still experiencing periods of partial packet loss lasting maybe 10 minutes, and occasionally longer, which are intermittently affecting both internet use, normal TV reception and TV catchup services. I can provide daily charts from the TB quality monitor to verify.
As before, a number of neighbours report problems at the same time, so it seems still to be an area problem. As for my own hub, signal levels and S/N all appear OK, but downstream errors are truly astronomical hitting 10 or 11 million pre and post errors after 6 days of operation: see below. This surely is way out of normal, and presumably indicates we still have a  noise problem?
Can you please advise how we can best escalate this issue? Thank you. NF
Cable Modem Status
Acquired Downstream Channel (Hz)    195000000    Locked
Ranged Upstream Channel (Hz)        43100000    Locked
Provisioning State                    Online
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    195000000    5    40    256 qam    8
2    139000000    3.9    38    256 qam    1
3    147000000    4.5    40    256 qam    2
4    155000000    4.5    40    256 qam    3
5    163000000    4.6    40    256 qam    4
6    171000000    4.9    40    256 qam    5
7    179000000    5    40    256 qam    6
8    187000000    4.9    40    256 qam    7
9    203000000    5.1    40    256 qam    9
10    323000000    5.3    40    256 qam    24
11    331000000    5.8    40    256 qam    25
12    339000000    5.8    40    256 qam    26
13    347000000    5.5    40    256 qam    27
14    355000000    5.5    40    256 qam    28
15    363000000    5.9    40    256 qam    29
16    371000000    6    40    256 qam    30
17    379000000    5.8    40    256 qam    31
18    387000000    5.9    40    256 qam    32
19    395000000    6.1    40    256 qam    34
20    403000000    6.4    40    256 qam    35
21    411000000    6    40    256 qam    36
22    419000000    5.8    40    256 qam    37
23    427000000    6    40    256 qam    38
24    435000000    6.3    40    256 qam    39
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    40.3    23112    38521
2    Locked    38.9    23046    37142
3    Locked    40.3    16307    30457
4    Locked    40.9    18863    25805
5    Locked    40.3    23881    32087
6    Locked    40.9    23671    32434
7    Locked    40.3    20233    32124
8    Locked    40.3    21125    76385
9    Locked    40.9    24805    308619
10    Locked    40.3    2058999    10986770
11    Locked    40.9    7269840    5735910
12    Locked    40.3    8930521    4061788
13    Locked    40.3    8023098    4985618
14    Locked    40.9    5856537    7170432
15    Locked    40.3    6102311    6928006
16    Locked    40.9    7757572    5249504
17    Locked    40.3    11235933    1671030
18    Locked    40.3    12280124    346672
19    Locked    40.9    11984568    123379
20    Locked    40.9    11545621    86417
21    Locked    40.3    11175458    93308
22    Locked    40.9    10399471    87703
23    Locked    40.9    8579957    76475
24    Locked    40.3    6138423    74627
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
1    43100000    42.5    5120    64 qam    2
2    36600000    42.3    5120    64 qam    3
3    23600000    41.8    5120    64 qam    9
4    30100000    41.8    5120    64 qam    4
5    49600000    42.5    5120    64 qam    1
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
1    ATDMA    0    0    11    0
2    ATDMA    0    0    4    0
3    ATDMA    0    0    9    0
4    ATDMA    0    0    3    0
5    ATDMA    0    0    8    0
General Configuration
Network access    Allowed
Maximum Number of CPEs    1
Baseline Privacy    Enabled
DOCSIS Mode    Docsis30
Config file    cmreg-vmdg505-bbt060-b.cm
SFID    273902
Max Traffic Rate    287500061
Max Traffic Burst    42600
Min Traffic Rate    0
Primary Upstream Service Flow
SFID    273901
Max Traffic Rate    27500061
Min Traffic Rate    0
Max Concatenated Burst    42600
Scheduling Type    BestEffort
Time    Priority    Description
17/08/2025 20:15:39    critical    No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
17/08/2025 14:58:40    Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
15/08/2025 05:06:35    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
15/08/2025 05:06:33    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
15/08/2025 05:06:33    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
14/08/2025 02:58:39    Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:48    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:48    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:8    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:8    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:4    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:46:4    Warning!    Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:45:59    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/08/2025 15:45:59    Warning!    RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
1 Reply
  • Hi nigelrjf,
    We're sorry to hear you're having continued issues, even after an engineer has visited. Checking our systems, I can see that there is an area fault open that is affecting you. The details of that are here:
    • ➡ Fault reference number: F011963404
    • ➡ Estimated fix time: 21 Aug 2025 22:20
    • ➡ Description: You might find that you don't have any Virgin Fibre, Voice, or Interactive Virgin TV services at the moment. We are sorry about this and are working hard to restore your services as soon as possible.
    The teams will be working hard to get things resolved as soon as possible for you. We apologise for any inconvenience.
    Many thanks,
