lohads's avatar
lohads
Speed keeps dropping
We are having to reboot our hub on a daily basis to keep the speed we should be getting.  We used to only have to reboot once a month but recently it has been getting worse.  Does VirginMedia every replace these?
  • jbrennand's avatar
    Firstly... Can we check… are your connection issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables?
    If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there lohads
    I am so sorry to hear that you are facing an issue with your service and a big thank you to jbrennand for their help here so far. Are you able to confirm if the issues are exclusive to WiFi or Ethernet?
    Can I just check also is the Hub in modem mode currently?
