yaktiswan's avatar
yaktiswan
Question related to Speed
Today is the 2nd day using virgin media router.
Yesterday I separated the 2.4 and 5ghz and as a result I was getting pretty much the top speeds upstairs as well
I’ve noticed the speeds have gone to around 200-250. Is the due to trafficking in the network
Ps- I have my own router - ASUS-AX82U WiFi Modem Router
  • AX 5400,
1 Reply
  • What is the speed on your package?
    Assuming you are using the hub in modem mode with the Asus router have you disabled the QOS settings on the Asus and ensured its firmware is current?
    Are there any local faults (on 0800 561 0061)?
