edam's avatar
edam
11 months ago
Powr up speed hub 3
It takes ages to power up the Hub 3 compared to the old Hub 2.
Is there any way to speed it up
    • edam's avatar
      edam
      Its a anxiety thing that I need to switch things off
        Let's hope you don't need to place a 999 emergency call via a Hub hosted telephone.
        That 10 mins Hub start up delay is going to be a source of real anxiety.
  • Tudor's avatar
    The hub, if you keep powering it off, searches to see if there are any updates every time. Like most electronic equipment it is not designed to be regularly turned off and on. The MTBF will increase drastically.
    I don't know what this fellow smokes, but can he share it with is all.
    Sheesh !
