SteveH14's avatar
SteveH14
4 months ago
Paid for upgrade to increased broadband speed - now slower than my old contracted speed !!
And virginmedia are blaming my home set up - couldn't make it up !!
    • Steven_L's avatar
      Steven_L
      Hello SteveH14,
      Welcome back to the Community, and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your connection at the moment.
      Are the issues that you're having a wired or WiFi connection to your hub? As Adduxi has advised, would you be able to run a wired speed test?
      Kind Regards,
      Steven_L
    Did you check online and over the phone as suggested in reply to your post <Here> ?
    If so was there any indication of area problems?
