max1000000's avatar
max1000000
M125 to M350 yet no change in speed
I upgraded my broadband from M125 to M350. Yet the speed remains at around its usual 90 Mbps.
Why is this please?
Max
  • jpeg1's avatar
    jpeg1
    Assuming this is an ethernet connection, the usual reason for this speed is that the remote device is only connecting at 100Mbps instead of 1000Mbps.
    Try a different cable, a different socket on the Hub, and check the ethernet settings in the device.
    On top of the advice from jpeg1 , you can also check the conf settings on the Hub. It will show what speed has been provisioned.
    It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate.
    You should see around 132 / 20 Mb/s on M125.
    Seeing 90 Mbps over an Ethernet connection suggests your computer equipment has a link speed of 100Mb/s,
    to go any faster you PC / laptop needs to connect to the VM Hub at 1Gb/s.
    The Connected devices menu of the VM Hub is a good place check network link speeds.
  • Daniel_Et's avatar
    Daniel_Et
    Hi max1000000, thank you for your query.
    If you could try following the excellent advice provided by jpeg1, Adduxi and Client62, that'd be much appreciated.
    If you're continuing to experience slow internet speeds thereafter, please let us know.
    General advice on how to fix this type of issue can be found here
    Regards,
    Daniel
    • max1000000's avatar
      max1000000
      None of that works. I'm a seasoned user and elec eng. Had a replacement routers over the years, you name it. Rebooted, no change etc. Needs someone to come in and look at it.
        Daniel_Et
        Hi max1000000, thank you for your response.
        In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
        Regards,
        Daniel
