jackydog
13 days agoTuning in
Low speeds
Hi I'm paying for 250Mbps but currently only getting 96 Mbps download on ethernet and slightly less on wifi on my main pc what can I do?
Link speed (Receive/Transmit): 100/100 (Mbps)
Link-local IPv6 address: fe80::7764:9ac2:47e3:2797%13
IPv4 address: 192.168.
IPv4 DNS servers: 194.168.4.(Unencrypted)
194.168.8.100 (Unencrypted)
Primary DNS suffix: cable.virginm.net
Manufacturer: Realtek
Description: Realtek PCIe GbE Family Controller
Driver version: 10.75.324.2025
Physical address (MAC):
A CAT 5e cable is all we need for a reliable 1 Gbps connection.
I don't read the PC is directly network cable connected to the VM Hub - is that the case ?
Or is there a 10/100 switch or 10/100 Powerline adaptor or some other network kit involved ?
Look carefully at the network socket on the PC, it needs to have 8 contacts and they all need to be undamaged to connect at 1Gbps. Same goes for the VM Hub end, where there are a choice of 4 network sockets to test with.
just noticed that my tv box is 1000 and thats with a at6 cable! are there any adjustments that can be made to the Hub?
I got a cat8 cable and download speed is still stuck at 100.Ethernet connection to the Hub is still at 100 ,NIC is set in Auto speed mode
I tried safemode with networking and got the same results- low for wired and correct for wifi.Also tried another pc and got the same results.
Someone on a suspicious number claiming to be from Virgin phoned me on my landline asking about my internet speeds and wanted me to turn on my PC and mobile .When I started to questioning him he rang off .Hope this forum is secure!
Realtek(R)PCI(e)Ethernet Controller is set to 1.Gbs full duplex
We are assuming the PC is directly connected to the VM Hub i.e. no use of 10/100 switches or Power Line Adaptors or and no use of a network cable plugged into a VM Pod / Wi-Fi repeater.
Login to the Hub menu and find out if the Ethernet connection to the Hub is at 100 or 1000
in the Hub's Connected devices list. If 100 try a different network cable.
I prefer to see a NIC of a computer to be set in Auto speed mode,
forcing the speed setting to 1 Gbps can result in no connection at all.
run powershell
Get-NetAdapter | where Status -eq "Up" | select InterfaceDescription, LinkSpeed
Thanks for advice guys.Real speed app shows speed at router is correct >250Mbps .I have now connected PC to wifi 5 GHz and speed is correct. I would like to know where the problem is as I am sur I got full speed in the past.Connecting cable is cat6 and the Realtek(R)PCI(e)Ethernet Controller is set to 1.Gbs full duplex
Try in safe mode with networking:
https://www.bleepingcomputer.com/tutorials/how-to-start-windows-10-in-safe-mode-with-networking
This will show if it's a software issue.
Regarding the Wi-Fi speed, for higher speeds make sure device is connecting to the Hub on the 5 GHz band. We see this info in the "Connected devices" menu of the VM Hub menus.
Assuming your devices have dual band Wi-Fi, it is the devices ( mobile / laptop etc ) that picks which band to use and if the slower but longer range 2.4GHz band is used speeds up to about 50 Mb/s are seen.
