  • Daniel_Et's avatar
    Daniel_Et
    Hi nazuro, thank you for your post.
    We're sorry to hear about the issues you've been having ๐Ÿ˜”
    How have things been since you posted? Also, have you tried changing your Hub back into router mode and checking the situation then?
    Advice on how to fix internet problems can be found here.
    Regards,
    Daniel
    • nazuro's avatar
      nazuro
      Hi Daniel, I responded a few days ago below, can you please check and review my monitor and advise if there's an issue on the line? Thanks
    • nazuro's avatar
      nazuro
      Thanks, I got a "B" https://www.waveform.com/tools/bufferbloat?test-id=98cfece1-91b1-423f-978d-f8dcc12eb9d2
      The latency only went up to 47ms. I also don't have huge downloads/uploads frequently. When I cross reference the latency spikes on the broadband monitor to my Unifi upload/download graph, I can't see a correlation. This is also from a wireless laptop, i'm sure the result would be better if I did it from my wired laptop.
      @Daniel - same issue. No, I haven't tried setting my hub back to router mode and I do not wish to do so. Are there any tests that can be done on your end by any chance. I followed the link you sent and input my details and it couldn't detect an issue (which is understandable as it seems to be transient..) and the help guides were mainly related to Wifi issues (I am on a wired connection).
      Thanks in advance
      Edit: I will try implementing SQM in my UDM-Pro.
      • legacy1's avatar
        yes but that average if you look at your download it spiked 153ms
        what speed are you on?
    Please post the power levels and network log from the Hub.  It might show some clues?  As an aside, if you are on a DOCIS network, it will have more latency than an FTTP connection.
    • nazuro's avatar
      nazuro
      Hi Adduxi thanks, does this help? There are some sporadic errors in the network log but not necessarily correlating with my latency issues
  • legacy1's avatar
    I'm on 250M for best rate limit here is what I use
    download 245760Kbps = 240Mb
    upload 25600Kbps = 25Mb
    The reason for the low limiting of download is to not buffer back on hubs rate limiting
    • nazuro's avatar
      nazuro
      Hi yes i've set something similar on my ubiquiti UDM Pro. Can't see how (or if I need to?) change this on the VM hub though.
      • legacy1's avatar
        well no you can't change rate limits on the hub or people will be going faster :p
  • Have you checked your router log ? You can see what errors youโ€™re getting g
    • nazuro's avatar
      nazuro
      A few things but nothing correlates with the timing of my latency spikes
