M_star99's avatar
M_star99
Superfast
Is my speed and connection ok?
hello all,
This maybe a one-off issue but i noticed yesterday i had drop-outs.  So i rebooted (i forgot to take stats before i rebooted!) the modem only Hub 5 and my router.  My stats are below, anyone notice if there is anything wrong? or all is ok?
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
138000000
7.3
40
QAM 256
1
2
146000000
7.1
41
QAM 256
2
3
154000000
6.9
41
QAM 256
3
4
162000000
6.9
41
QAM 256
4
5
170000000
6.9
41
QAM 256
5
6
178000000
6.8
41
QAM 256
6
7
186000000
6.8
41
QAM 256
7
8
194000000
6.8
41
QAM 256
8
9
202000000
6.6
41
QAM 256
9
10
210000000
6.7
41
QAM 256
10
11
218000000
6.8
41
QAM 256
11
12
226000000
6.6
41
QAM 256
12
13
234000000
6.7
41
QAM 256
13
14
242000000
6.6
41
QAM 256
14
15
250000000
6.6
42
QAM 256
15
16
258000000
6.8
42
QAM 256
16
17
266000000
7
42
QAM 256
17
18
274000000
7.1
42
QAM 256
18
19
282000000
7.2
42
QAM 256
19
20
290000000
7.2
42
QAM 256
20
21
298000000
7.1
42
QAM 256
21
22
306000000
6.8
42
QAM 256
22
23
314000000
6.7
41
QAM 256
23
24
322000000
6.5
41
QAM 256
24
25
330000000
6.5
41
QAM 256
25
26
338000000
6.6
42
QAM 256
26
27
346000000
6.5
42
QAM 256
27
28
354000000
6.4
42
QAM 256
28
29
362000000
6.4
42
QAM 256
29
30
370000000
6.5
42
QAM 256
30
31
546000000
4.7
42
QAM 256
41
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40
6
0
2
Locked
41
2
0
3
Locked
41
2
0
4
Locked
41
2
0
5
Locked
41
0
0
6
Locked
41
0
0
7
Locked
41
3
0
8
Locked
41
1
0
9
Locked
41
1
0
10
Locked
41
1
0
11
Locked
41
1
0
12
Locked
41
3
0
13
Locked
41
0
0
14
Locked
41
2
0
15
Locked
42
0
0
16
Locked
42
0
0
17
Locked
42
2
0
18
Locked
42
2
0
19
Locked
42
0
0
20
Locked
42
1
0
21
Locked
42
1
0
22
Locked
42
1
0
23
Locked
41
0
0
24
Locked
41
3
0
25
Locked
41
0
0
26
Locked
42
0
0
27
Locked
42
1
0
28
Locked
42
0
0
29
Locked
42
0
0
30
Locked
42
0
0
31
Locked
42
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
92
4K
1800
QAM 4096
1128
Channel ID
Locked Status
RxMER Data (dB)
PLC Power (dBmV)
Corrected errors (Active Profile)
Uncorrectable errors (Active Profile)
33
Locked
42
5.2
31479651
0
    • M_star99's avatar
      M_star99
      Superfast
      Channel
      Frequency (Hz)
      Power (dBmV)
      Symbol Rate (ksps)
      Modulation
      Channel ID
      0
      49600000
      45.8
      5120
      QAM 64
      7
      1
      43100000
      45.5
      5120
      QAM 64
      8
      2
      36600000
      45
      5120
      QAM 64
      9
      3
      30100000
      45
      5120
      QAM 64
      10
      4
      23600000
      45
      5120
      QAM 64
      11
      3.0 Upstream channels
      Channel
      Channel Type
      T1 Timeouts
      T2 Timeouts
      T3 Timeouts
      T4 Timeouts
      0
      ATDMA
      0
      0
      0
      0
      1
      ATDMA
      0
      0
      0
      0
      2
      ATDMA
      0
      0
      0
      0
      3
      ATDMA
      0
      0
      0
      0
      4
      ATDMA
      0
      0
      0
      0
      3.1 Upstream channels
      Channel
      Channel Width (MHz)
      Power (dBmV)
      FFT Type
      Modulation
      14
      10.4
      41.5
      2K
      QAM 256
      Channel
      Channel Type
      T3 Timeouts
      T4 Timeouts
      14
      OFDMA
      208
      74000000
      0
      0
  • I am using my ASUS router yes.
    Did you mean Universal Beamforming and Explicit Beamforming? as those are what i have on my asus router.
  • legacy1's avatar
    one-off issues do happen likely your connection is now fine
    As noted, setup a BQM to record the incoming circuit.  This will show if the dropouts are on the WAN side.
    Also put the Hub back to Router mode and run the FULL tests on http://www.samknows.com/realspeed using a Cat 6 cabled connection.  This will show the incoming stats to the Hub, hence the need for Router mode.
  • Universal Beamforming and Explicit Beamforming? leave on or turn off?
    • Steven_L's avatar
      Steven_L
      Hello M_star99,
      Welcome back to the Community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your connection at the moment.
      I've looked into this from here and cannot see any issues with your connection or in the local area. How have things been running and working since you last posted?
      Kind Regards,
      Steven_L
      • M_star99's avatar
        M_star99
        Superfast
        Hello Steven_L,
        So far its been fine.  Although i was reading on here i SHOULD restart my hub every-now and again.  Any idea how frequently i should do this? also what times should i do this?
