Takingthemick's avatar
Takingthemick
Is it even possible to get close to full speed via modem mode?
I am using a TP-Link Archer AX11000, but i am wondering if it's even possible to get close to 1GB through it? While doing speed tests i get between 500/600, obviously when i use the VM hub for testing purposes i get 1.1GB at least which is normal. I've seen people claiming to get over 1GB with modem mode/routers, yet the closest i got was with a cheap switch that kept breaking/disconnecting so i sent it back to Amazon. I've put my PC in safe mode with networking and it has gone up a lot more, but i am wondering at this point what is causing the speed bottleneck in the background of my pc too. Thanks.
  • Roger_Gooner's avatar
    Roger_Gooner
    With the hub in modem mode connect only a PC/laptop and see what speeds you get.
  • legacy1's avatar
    what do you mean you get 1.1Gb with the hub is that by realspeed?
    test hub in modem mode without a router and see what speed you get.
  • Tudor's avatar
    Simple answer yes. Hub5 modem mode and Ubiquiti Dream Machine Pro router. Speed test run on my router today:
    Jul 7 04:28:27 linkcheck[746]: linkcheck[746]: linkcheck.run_speedtest(): Completed: Downlink 1154.000 Mbps, Uplink 105.000 Mbps
