SHOUTINGPIRATE
2 years agoOn our wavelength
Internet Speed Inconsistent
Hi, I am experiencing a strange issue where my network speed seems to be dependant on load. I have 1GB from Virgin, with the hub in modem mode and Google WiFi and I am experiencing this both wired a...
- 2 years ago
Check your Google Wifi configuration. If you have any kind of QoS or 'Application / Gaming' enhancement on - turn it off.
The Google Mesh hubs are known for having 'broken' QoS configs that get fixed in a newer firmware, then get broken again on another release / update. That's why your speed tests are intermittent as it sounds like QoS is kicking in - and throttling your tests intermittently. The firmware for the Google mesh system ( and the majority of Google's kit ) is shocking. US tends to get fixes - while us lowly people in the UK have to wait months if not longer to see the same 'fixes' applied.
