GeorgeG24's avatar
GeorgeG24
Just joined
Internet speed 500Mbs on 1 gig
Hi, was wondering if anyone could help, I've had virgin media for just over a year. My package is the gig1 and the problem I've had since day one is my download speed only gets to about 400-500mbs. I'm about to start paying £80 a month for half of the 1130mbs what I'm promised . I was wondering if there is anything I can do or any recommendations that could help.
  • hat does the speed test at https://www.samknows.com/realspeed/ say?
    If the first column (Router) is nowhere near 1000Mbps then call in a fault.
    If 'Router' it is over 1000Mbps then the issue is within your location - most likely the kit being used can not handle that speed. Wifi will usually struggle.
