andyads74's avatar
andyads74
Hub 4 playing up
Hello
I've had a Hub 4 router for a while now with minimal issues but in the last couple of weeks it has randomly started doing white flashing lights (probably 5 or 6 times), which has meant I've had to re-boot it. Does this sound as though it is faulty and should be replaced?
  • jbrennand's avatar
    is this still an issue?
    Can you check first for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
  • Sabrina_B's avatar
    Sabrina_B
    Hi andyads74 👋.
    Thanks for reaching out to us, apologies for the issues that you have been facing with your Hub 4 recently. Can we ask since your post have you been able to get this resolved or are you in need of further assistance in this matter.
    Please let us know ASAP.
    Sabrina
    • andyads74's avatar
      andyads74
      Hello Sabrina
      The hub has had the flashing white light on a couple more occasions and again we had to switch the hub off and on to resolve. Once was during an online meeting which was very frustrating. It is sporadic so can be fine for a few days and then randomly start flashing.
      • John_GS's avatar
        John_GS
        Hi andyads74
        Thanks for coming back to us. You need an engineer visit. This is because the upstream channels, some of them are out of spec. I'll send you a PM now to book this visit in.
        Best wishes.
