Johnnyboy123
11 months agoTuning in
Is that based on the data I posted, or just a general observation?
11 months agoAlessandro Volta
Bit of both
If you want proof now you can put the hub in modem mode with a PC and see if its stable but then your problems are wifi so take it what you will.
- Johnnyboy12311 months agoTuning in
Sorry, just trying to get to the bottom of this. If you're saying that the data I provided means the hub isn't working correctly, then surely VM should provide a hub that's fit for purpose.
Related Content
- 7 months ago
- 5 months ago
- 4 months ago
