Vindiesel5000's avatar
Vindiesel5000
Brown box damaged
Hi. My VM wifi has been intermittent and also slow for around two months now.
move reported on then phone (6 weeks ago) to be told works were being done in the area.
6 weeks later wifi is still dropping out and when it does work, is slow.
The brown box on the outside of the house is also damaged and won’t stay shut so it’s exposed to the elements.
Can someone please help?
thanks
  • Re the omnibox cover - post up a photo here for a VM person to assess thr damage and arrange a "fix".
    Re. the connection issues...
    Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
    What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
    Also,
    check for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    Post back here what's reported on those two.
  • jbrennand's avatar
    Also,
  • Hi, John, thanks for your reply.
    Ive currently glued their box together so no point taking a photo - it’s VERY old though ad suffered damage with the wind & rain etc over time.
    Service checker website showed no issues. Tel service shows there are no issues in the postcode either.
    It’s a Hub 3. The light on the front is yellow currently.
    • Vindiesel5000's avatar
      Vindiesel5000
      I don’t have any devices that have an ethernet port so cant comment there
        You can get adapters with ethernet ports that will connect any device to the Hub via any port your device has - I have them with USB3, USBc, T'bolt, firewire and lightning - so I can connect any of my many Apple devices.  Amazon has a good selection
        Lets see your connection details - do this...
        _____________
        In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
        Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
  • EV5's avatar
    EV5
    Our brown box cover has come off and the wires are exposed. I’ve tried calling and messaging the bot but as there are no options that cover this, I couldn’t get any help.
  • Hi do we still need the brown boxes or can I remove as we have gone digital?
    • David_Bn's avatar
      David_Bn
      Thanks for reaching out to us unhappy65, and welcome back to our Community Forums!
      We would advise not removing the brown box as this is still vital to the services being provided to your property.
      Removal of this would simply disconnect the services.
      David_Bn
