RBZ24's avatar
RBZ24
2 months ago
Broadband speed very slow
I've been experiencing regular drops in speed recently - this is what I'm getting this morning and it's regularly been around 20mbps for the past couple of days. I've restarted the router (which is not very old) but no improvement. We normally get between 350-450mbps. Any idea what's going on?
    1) From the VM Hub menu
    Check the Downstream and Upstream connection stats.
    2) Check for known faults in your street. Try both methods:
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    3) With VM Hub in Router mode...
    Check the Service Speed at the Hub:
    https://real-speed-fe.eu1.sk.thousandeyes.com/
    Once the test begins click on: Run full test
    to include: Latency, Jitter, Packet loss & Upload speed.
    • Steven_L's avatar
      Steven_L
      Hello RBZ24,
      Welcome back to the Community, and thanks for taking the time to post. I’m sorry to hear of the issues that you’re experiencing with your connection. I've looked into this and cannot see any issues in your area or with your individual connection. Are you still experiencing the same issues or have the issues now been resolved?
      Kind Regards,
      Steven_L
      • RBZ24's avatar
        RBZ24
        Hi Steven - we are still experiencing the same issues. Extremely slow speeds with no obvious explanation. Is there anything you can do to help? We may need an engineer to visit
