AlexVN's avatar
AlexVN
5g WiFi is very unstable, speed is inadequate, wired connection is ok
Recently, the wireless connection speed on my VM Hub dropped significantly. The speed test shows about 11.4 Mbps download, while the wired connection shows 255 Mbps download. I'm connecting to the WiFi 5G endpoint, close to the router. I have another 5G router from a different provider, and it works fine. I've restarted the hub several times and reset it to factory settings (pressed reset on the back for 30 seconds, tried restarting and resetting in the Web Admin), tried difference channels (making sure that they are not busy with WiFi scanner for Android on my phone), - the speed is still very slow.
The check on the VM website tells me, "Looks like there’s an issue affecting the broadband service in your home," and suggests either contacting the VM team or restarting the router. I've run out of ideas on what to do. Any suggestions?
    You will need to call VM.  If there is an area problem VM will not send an engineer until this is resolved.
  • I do not think there is an area problem. I would rather suspect Hub's WiFi issue, because wire works well.
    Try the VM Hub with:
    1) Smart Wi-Fi aka Wireless Channel Optimization Disabled.
    2) 5GHz Wi-Fi set to Channel 36 or 44
