jonny5mm's avatar
jonny5mm
10pm fiber drop out
Did you manage to sort this ? I have just got virgin and the same thing happens at 10.30 all tv streaming stops but I do the check/test on the phone and all is good but can load anything on the tv and then about 23.00 tv internet streaming again
[MOD EDIT: Post split to create own thread]
  • Hi jonny5mm,
    We're sorry to hear you're having some issues with your connection dropping out at 10.30 each day. Running some checks here, we can see there are no faults in the area that are affecting you. We've run some tests on your hub itself and can see several of your downstream power levels are too high. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
    I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
  • Hi jonny5mm,
    Thanks for coming back to via private message to confirm your information. 🤩
    I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here 👉 My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
    Just to confirm, there will be no charge for this visit unless:
    • ➡ The technician diagnoses the faults as not being caused by our network/equipment
    • ➡ The technician discovers that the fault or problem relates to your equipment
    • ➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
    • ➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
    Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
    We will continue to monitor your services and if we can see that the fault has cleared and the visit is no longer required we will cancel the appointment and let you know by text and email.
    Let us know how the appointment goes. 😊
    Take care.
