justinbowness's avatar
justinbowness
Which HUB 5 router power cable!!!
Hey everyone.
First post here!
Ive read and read about different cables but i need to relocate my router to a different location.
1) - I got new cat 7 cables, new coax cables / splitter etc - all worked fine 😇
Then finding a power input cable has been a NIGHTMARE!!  😡
I thought it was just a normal 2.1mm x 5.5mm low power extention cable which could between the original virgin cable and the hub 5.
What the hell do i do ?   im desparate as ive moved everythng else and currently have no power without extension leads everyware.
Thanks in advice everyone.
Any links to the correct cable required would be brilliant. It looks like the pin that goes in the bottom of the hub has a different 'grip' end on it.
