Neil001's avatar
Neil001
VM Connect won’t connect to Hub5
I’m trying to use the VM Connect app, but it can’t detect my router, Hub 5. I’ve followed all the troubleshooting steps - no VPN, cleared app data etc - but still no luck. The hub was installed a long time ago so it can be related to a new install.
What should I do?
1 Reply
    The Connect app requires Apple Relay to be disabled if you use Apple kit.
    Manage the Hub 5 at http://192.168.0.1/    use the Hub password ( not the Wi-Fi password )
