colshep's avatar
colshep
Removal of unwanted external box and cable
Hello,
We are renovating our house and have an unwanted and unused external box and cable that we would like to remove how do we arrange for their removal?
  • jpeg1's avatar
    jpeg1
    VM are usually very reluctant to remove them in case a future resident might want to use them.  Give them a couple of weeks to respond, but if you have to remove the cable and box yourself they are quite harmless.
  • Daniel_Et's avatar
    Daniel_Et
    Hi colshep 👋 Thank you for your query and welcome to the Virgin Media Community 😀
    Would removing the unwanted external box and cable yourself be possible or would you definitely like us to look into arranging an engineer visit if we can?
    Thank you for your support jpeg1 👍
    Regards,
    Daniel
    • colshep's avatar
      colshep
      Hi Daniel
      We can remove the box and the cable that runs down the house. However we wont be able to remove the section of the cable goes across the road and is attached to a telegraph pole this would need to be removed by an engineer.
      Colin
      • Molly_T's avatar
        Molly_T
        Hi Colshep 👋 Thanks for getting back to us!
        We will need to confirm a few details so we can arrange getting the cabling removed.
        Keep your eye on your Inbox 📩 in the top right corner of the page for My PM offering support. Thanks for your patience in the meantime! 🌞
  • nodrogd's avatar
    nodrogd
    Overhead cable drops are not normally removed unless they are a safety hazard. This applies to all operators, not just Virgin.
    Also, unless this installation is very new it will not be Virgin infrastructure, as 98% of their service drops are underground.
