Trix71x's avatar
Trix71x
power cable for the hub 5
Hi, can you get a longer power cable for the hub 5. I need approx 5m to locate the hub in the required location.
  • Hello Trix71x.
    Thanks for your post and welcome back to our community.
    If it's just the white coax cable you require, we can get one sent out for you from here. They do come in 5, 10 and 15 metres.
    What I'll do is send you a private message to pass security.
    If you can check the envelope top right of your screen that would be great.
    Gareth_L
  • Tudor's avatar
    Use a mains extension cable, extending a DC cable for something like a hub is asking for trouble.
  • jpeg1's avatar
    jpeg1
    If you are moving the Hub you'll need a longer coax lead too. Only Virginmedia supplied leads should be used.
  • Thanks all.
    There's plenty of length on the coax. Don't want to use an extension that's why I was asking if anyone knows you can get longer power cable. It's not in two parts ie. DC & AC.
    Not getting anywhere trying to get an answer from virgin direct.
    • Gareth_L's avatar
      Gareth_L
      Hello Trix71x.
      Gareth_L
