MacmillaN's avatar
MacmillaN
Hub 5 Connection issues.
We are experiencing random connection drops during the day, here are the modem stats, for you to hopefully spot something, all connections are tight!
3.0 Downstream channels
12270000006.141QAM 25612
21390000005.940QAM 2561
3147000000640QAM 2562
41550000006.140QAM 2563
51630000006.340QAM 2564
61710000006.341QAM 2565
71790000006.341QAM 2566
81870000006.341QAM 2567
91950000006.741QAM 2568
102030000006.641QAM 2569
112110000006.741QAM 25610
122190000006.441QAM 25611
132350000006.141QAM 25613
142430000006.141QAM 25614
152510000006.141QAM 25615
162590000006.241QAM 25616
172670000006.741QAM 25617
182750000007.241QAM 25618
192830000007.141QAM 25619
202910000006.841QAM 25620
212990000006.341QAM 25621
223070000005.941QAM 25622
233150000005.841QAM 25623
24323000000641QAM 25624
253310000006.241QAM 25625
263390000006.341QAM 25626
273470000006.341QAM 25627
283550000006.341QAM 25628
293630000006.241QAM 25629
303710000005.841QAM 25630
313790000005.741QAM 25631
1Locked4188133
2Locked40177112
3Locked4012112327
4Locked4047893549
5Locked408232207
6Locked4110003602
7Locked416172528
8Locked416172852
9Locked414892228
10Locked416453200
11Locked416723449
12Locked416941707
13Locked418212983
14Locked417172432
15Locked417602656
16Locked419953452
17Locked4110683772
18Locked419962712
19Locked4110082884
20Locked417552888
21Locked4110934135
22Locked417622533
23Locked419133062
24Locked416212442
25Locked417702886
26Locked4110463565748
27Locked416513161
28Locked4110614119
29Locked418374413
30Locked417493469
31Locked416753266
3.1 Downstream channels
33944K1840QAM 40961108
33Locked400.13378310427139269
3.0 Upstream channels
04960000045.55120QAM 641
14310000045.55120QAM 642
23660000045.55120QAM 643
33010000045.55120QAM 644
42360000045.85120QAM 645
0ATDMA0000
3ATDMA0010
4ATDMA0000
3.1 Upstream channels
1210.440.72KQAM 256
12OFDMA20874000000240
  • Tudor's avatar
    Those stats usually indicate noise ingress, but not always. You definitely need a technician’s visits to rectify..
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
    • Matthew_ML's avatar
      Matthew_ML
      Hey MacmillaN, thank you for reaching back out and I am sorry to hear you are having some connection issues.
      I have taken a look and I can see you levels are very good.
      How has the connection been over the weekend?
  • MacmillaN's avatar
    MacmillaN
    Good Evening @Matthew_ML
    as mentioned previously in the comments, other users are saying it’s unusual to have 'Post RS Errors'. Possibly a bad hub and those stats usually indicate noise ingress, my hub was before posting the stats experiencing random connection drops!
    Thanks for your time!
    • Paul_DN's avatar
      Paul_DN
      Hi MacmillaN,
      Thank you for reaching back out, I was able to check again today and everything still looks good, please keep an eye on things and if you do face further issues keep a log.
      Paul.
