Customer66's avatar
Customer66
9 months ago
Hub 5 arrived today - but DOES NOT WORK!
Had notification my router (Hub 3) needs to be replaced / upgraded
Received the new one today a Hub 5 – plugged it in and switched it on – white constant light
Connected phone to Wifi using "scan to connect" – wifi connected – no internet – slow blue flashing light on router
Checked connection of coaxial cable – which was fine – restarted router – told phone to forget network and connected again this time via manual entry of password - same outcome
Tried connecting my PC just in case it was a phone thing – same outcome – wifi connected – no internet connection – router still flashing blue.
restarted router again - same outcome
Reconnected the old Hub 3 and i have internet again – but as I understand it VM will switch this off in a few days as part of the “upgrade” - and i cannot be without internet as i need it for work
seems like the new router has a problem
Can anyone help before i lose internet access ???
  • This probably means that the new hub has not been initialised for you account.
    Call the pre-installs team on 0800 052 1734 8AM- 9PM Monday - Friday or 8AM-6PM Saturday and Sunday and ask for the hub to be initialised.
  • Tudor's avatar
  • thanks for the quick response
    looks like have just missed them for today - but i can certainly try that tomorrow
  • ok - it took a few attempts  - but that seems to have fixed it
    thanks for the help
