WestSussexFlats's avatar
WestSussexFlats
4 months ago
Installing VM Fibre to Block of Flats
We have a block of 24 flats in West Sussex. The flats are situated in a street where Virgin media fibre has been installed to every property in the street apart from the block of flats. In fact there's literally a Virgin media telegraph pole next flat grounds entrance. There are some Virgin fibre cables connected to this telegraph pole which passes the block of flats to the two neighbouring buildings down the street.
The previous estate Director said the Virgin Media fibre network was installed in the street a few years ago there was a plan to connect the flats to the network but due to the pandemic it was paused then never restarted. I've only recently taken over as Director and wasn't part of previous discussions so that's about as much as I know and unfortunately the other Directors aren't sure about the previous plan.
As mentioned, there are 24 flats in the block and we a fibre connection, therefore, presumably this may be an attractive opportunity for VM. Additionally, the other Directors and myself are happy to explore and sign up to wayleave if required.
I did previously speak with someone over the phone on customer service who stated they would look into this and get back to me, but I haven't heard anything for over a month.
Just wondering if this is something that can be explored as we're really keen to get fibre installed and given there is a relatively new VM fibre network in the street with a connection point very close, I'm guessing this wouldn't be too onerous to have installed?
  • Notice a mistake in the post above, the third paragraph should say:
    "As mentioned, there are 24 flats in the block without fibre connection, therefore, presumably this may be an attractive opportunity for VM. Additionally, the other Directors and myself are happy to explore and sign up to wayleave if required."
    • John_GS's avatar
      John_GS
      Hello WestSussexFlats
