DW26's avatar
DW26
Removing fibre cable
Currently with UPP broadband but my contract ends on the 1st June when it switches to Virgin. How will my old fibre cable be removed ???
    • DW26's avatar
      DW26
      I have tried but they said they won't take it down
      • Latedev's avatar
        Latedev
        Why would they take it down?
        Surely Virgin will be using that fibre for its services?
  • jpeg1's avatar
    jpeg1
    As an aside, are you certain that there will be no delay with the Virgin service?
    New VM connections which require a cable installation are often delayed, and it is usually recommended on here that an existing service is not cancelled until VM is in and working satisfactorily.
  • Roger_Gooner's avatar
    Roger_Gooner
    UPP's network will be absorbed into nextfibre's. As nextfibre is a wholesaler there could be another ISP who wants to deliver service, thus providing competition to VM. The last thing you want to do is get the cabling removed even if you were allowed to do so.
  • DW26's avatar
    DW26
    I already have a new supplier with a totally new fibre connection I have no use for the old one
  • goslow's avatar
    goslow
    This might just be the shape of things to come. I have a redundant VM coax cable, a working BT fibre cable and am now looking at replacing that with an alt-net connection which will come via another fibre (yet to be installed). If the future requires us to switch suppliers every 18 months to 2 years for cost reasons, you might need all of your connections in place to be able to switch easily and without additional future cost. It would make no sense from a supplier's POV to go around removing their infrastructure once it is installed.
