Hub 3.0 overheating llight (RED) go red after few seconds after rebooting
Hi, We started to have few issues with our network and I am coming to conclusion its the HUB 3.0 overheating as the LED reports RED all the time and when rebooted it goes purple for few seconds and then red again , while the speed stay constant for over 300Megabits, we get quiet ofted what appers to be dropout in network where everything feezes and then comes back again this is happening both via wifi and wired network, sometimes even I get notification on my work laptop that status of my network has changed. I've tried to run diagnostics on the HUB 3 but with the FW changes now you can't monitor temperature on it, the the diagnostics recomends checking temperature it dosn't report it anymore. The casing of the hub is warm to touch but that dosn't directly indicate its overheating The setup is HUB3.0 in modem mod only netgear passive switch 1gbps for ethernet plugs around home and mess network with Archer C80 and RE605X hotspots I just started network mnonitor <a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/b26ce463c31e865108bfc94f3e5ed84b1757f49f">My Broadband Ping</a>146Views0likes7Comments
