TV 360 and Hub connection
kamren
Hi needed help as my TV 360 does not work with my current coaxial cable that is in my living room and my hub is upstairs, not possible to run a wire down to connect it either.
1 ACCEPTED SOLUTION
Accepted Solutions
You will need to call Virgin on 150 and ask for a manned installation, if you have only just added TV to your account then there might not be a charge otherwise it will be a £25 charge for a manned installation.
4 REPLIES 4
roy247
Superstar
Is the coax cable a Virgin cable or TV aerial coax.
The 360 box needs a coax connection to the box for live TV and a connection to your hub either by ethernet cable or WiFi.
If you don't have a coax connection where your TV is you need to phone and ask for a manned installation which should be £25.
pretty sure a tv aerial coax.
Hey Kamren, thank you for reaching out and  a warm welcome to the community I am so sorry to hear this.
Let me send you a DM now so we can look into this.
Matt - Forum Team
New around here?
