jamboman125's avatar
jamboman125
virgin telly tablet problem
afternoon
hope someone can give me some advice.
i have had the virgin telly tablet since i joined virgin..dont use it a lot but tried to use it yesterday and its dead...thinking it mught just be out of power i had in plugged into mains for 30 minutes but still cant switch it on...i seem to remember reading that you can use the on/off awitch and the up/down switch but still nothing...
can anyone offer some advice?
john
1 Reply
    Hi John,
    Sorry to say but it does sound as if the battery is dead like the Norwegian Blue parrot in the Monty Python sketch.
    I don't know if the following contact details will still help as the telly tablet was considered end of life in 2021 but you could contact the telly team by emailing them via virginsupport@exertis.co.uk  or by phoning them on 01282 858460.
    They might have or be able to replace the battery, but in all honesty I wouldn't be too hopeful.  Your best bet might be to see what bargains are available to buy on Amazon Prime day (16th and 17th July although they do have deals prior to that)
    Did you try holding the power button for around 30 seconds to a minute to see if that sparked the tablet into life?
    The following shows how to reset the telly tablet and may also help get it working.  Try holding the volume uphome and power buttons at the same time for 10/15  seconds and if there is any power left then you should see an Android  robot or the VM logo, Then use the volume down button to scroll down to reboot
    (you might have to go through the wipe cache partition process before you get the reboot option which is)
    Hold the volume uphome and power buttons at the same time for 10/15  seconds you see an Android  robot or the VM logo. Use the volume down button to scroll down to wipe cache partition, then press the power button. When wiping the cache partition is complete use the volume keys to select reboot system now and then press the power button again. The telly tablet should then reboot in working order.
