rich_simpson's avatar
rich_simpson
Issues with HUB 3 - cannot get through to VM
Hi,  My broadband has degraded to hopelessly slow and disconnects often over the last month. The HUB3 (in modem mode) has a constant red light (but is not hot) the logs are full of these entries every few seconds.
23/11/2024 12:31:56Warning!RCS Partial Service;CM-MAC=xxx;CMTS-MAC=xxx;CM-QOS=1.1;CM-VER=3.0;
23/11/2024 12:31:56Warning!Lost MDD Timeout;CM-MAC=xxx3;CMTS-MAC=xxxe;CM-QOS=1.1;CM-VER=3.0;
 Whether I call or chat to VM support I end up back in the chatbot (the call system eventually tells me there is not fault and  texts me a link to the chatbot then cuts me off so i go through the chatbot and end up being told I need to be transferred to WhatsApp and then no whatsapp message ever comes through (tried on different days so its not just being impatient). I have done all the things said by the chatbot including the factory reset but nothing makes it any better. Can anyone help or at least tell me how to get through to speak to VM or get the whatsapp to work - I have been transferred to the VM whatsapp service in the past and it was great but it no longer seems to work?
  • jpeg1's avatar
    jpeg1
    VM don't want you to call them.  It costs them time and money to deal with your problems so they would rather you didn't bother them.
    But you will get some good advice here. Post all the data from your Hub, and tell us what equipment you are using and how it's connected to the Hub.
  • Tudor's avatar
    1) Those messages should be ignored, they are only warnings.
    2) The LED on a Hub3 when in modem mode should be magenta, this can look red to many people.
    3) please post a full set of stats, details below:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
    • rich_simpson's avatar
      rich_simpson
      Thanks, - I remember it was Magenta in the past but checked with all the family and they all think its definitely red now!
      I have BQM which i set up when it started intermittently resetting and having terrible speed issues (also intermittently) BQM Live view
      In the time its taken to logon to the hub and get this info it has reset on me twice - back to flashing yellow\white with green arrows then back to red. That is worse than usual (wondering if logging on to it sent it over the edge) but its been doing that several times a day  for a while.
      13310000000.737256 qam25
      2139000000-3.531256 qam1
      3147000000-2.228256 qam2
      4155000000-2.930256 qam3
      5163000000-330256 qam4
      6171000000-2.431256 qam5
      7179000000-2.731256 qam6
      8187000000-2.229256 qam7
      9195000000-226256 qam8
      10211000000-1.727256 qam10
      11219000000-1.527256 qam11
      12227000000-2.230256 qam12
      13235000000-1.732256 qam13
      143070000000.229256 qam22
      153150000000.231256 qam23
      16323000000036256 qam24
      17339000000035256 qam26
      183470000000.533256 qam27
      19355000000-0.237256 qam28
      203630000000.435256 qam29
      21371000000031256 qam30
      22379000000031256 qam31
      23387000000032256 qam32
      1Locked37.3142141
      2Locked31.4194790712415
      3Locked28.31097444959692
      4Locked30.81884372167874
      5Locked30.51745186310275
      6Locked31.6199265915376
      7Locked31133593929382
      8Locked29.71111256508253
      9Locked26.43870511636675
      10Locked27.93967371628574
      11Locked27.85965351432541
      12Locked30.46555783228
      13Locked32.65121904355
      14Locked29.5629562953134
      15Locked31.66233929847
      16Locked36.6158181
      17Locked35.7135237
      18Locked33.918696311
      19Locked37.390281
      20Locked353242428
      21Locked31.779113659006
      22Locked31.1830086107376
      23Locked3254954810229
      13659994749512064 qam3
      22359997649512064 qam5
      33010001449512064 qam4
      44309994449512064 qam2
      54960000449512064 qam1
      3ATDMA0000
      4ATDMA0000
      5ATDMA0000
  • Downstream SNR is much too low (should be at least 33dB), there is likely to be an SNR fault in your area. If not VM will arrange an engineer visit to look into it.
    Chances are the red light isn't the cause of the problem. In Modem Mode the magenta colour can fade over time and eventually appear to be red.
      rich_simpson
      thank you - that makes sense as my upstream speed is fine on any test i run. The system status and VM's call and chatbot systems all say there is no fault in the area - However that leaves we with the problem of how to call or contact VM as i just go round in circles being told they will whatsapp me and then cutting me off.
      • Tudor's avatar
        Those figures look very bad. Low downstream & high upstream power usually indicate one of two things. 1) you are a long way from the street cabinet and need to be on a different tap in the street cabinet 2) there is a bad connection between the hub and the street cabinet. Check all cables are tightly screed in and then you need to contact customer services as a fault.
    Check Hub 3 Temperature ... login in to the Hub 3 menu at http://192.168.100.1/   ( for modem mode )
    use the numeric Hub password from the bottom side label.
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry.   Is it:  Normal  ?
      rich_simpson
      Thanks - but I cannot find any network diagnostics tool - only network status, which does not have temperature anywhere
      rich_simpson
      ah ok - I guess I have to switch it back to router mode to see that!
        rich_simpson
        Ok - now back in router mode - initial results look similar to modem mode at speed.cloudflare.com which show c6% packet loss and speeds well below the 350Mb I used to get (and what my service is supposed to be) but its the packet loss that concerns me I dont see that even a 0.1% loss at all on other networks I use cloudflare on - not even a 4g one. - we'll see if BQM sees any difference.
        (wifi is off and using 1Gb/s Ethernet to the Hub for the below).
      rich_simpson
      Ok - found it now - have to be in router mode! - It says temperature is normal.
  • Alex_RM's avatar
    Alex_RM
    Hi rich_simpson,
    Thanks for posting and welcome to our community 😊
    Sorry to hear you're having some connection issues. We've had a look from our side and no issue are flagging up. You've mentioned you're using a third party router, are you able to disconnect this and let us know if there is any change/ let the BQM run whilst in router mode for us.
    Alex_Rm
      rich_simpson
      Thanks Alex, I had discounted any probs on the LAN side as I didn't think the LAN side would\could cause the hub to drop signal and cycle but I will give that a go.
      Rich
      • jpeg1's avatar
        jpeg1
        And you're quite right, of course.
    • legacy1's avatar
      Now can you see the SnR is low!😬
      rich_simpson
      So with my router disconnected and Hub 3 back in router mode - still getting poor download and ok upload
      Network status stuff below.
      13310000000.238256 qam25
      2139000000-431256 qam1
      3147000000-2.531256 qam2
      4155000000-3.232256 qam3
      5163000000-3.431256 qam4
      6171000000-2.733256 qam5
      7179000000-334256 qam6
      8187000000-2.735256 qam7
      9195000000-2.535256 qam8
      10203000000-2.536256 qam9
      11211000000-2.234256 qam10
      12219000000-231256 qam11
      13227000000-2.733256 qam12
      14235000000-2.237256 qam13
      15307000000-0.437256 qam22
      16315000000-0.238256 qam23
      17323000000-0.537256 qam24
      18339000000-0.737256 qam26
      19347000000038256 qam27
      20355000000-0.738256 qam28
      21363000000-0.238256 qam29
      22371000000-0.538256 qam30
      23379000000-0.538256 qam31
      24387000000-0.538256 qam32
      1Locked38.670261961
      2Locked31.1110709122125806932
      3Locked31.9154503976276239924
      4Locked32.715700954642517528
      5Locked31.915963443306488796
      6Locked33.91026171434186086
      7Locked34.910571587142524411
      8Locked35.7124198854732913426
      9Locked35.51008302103349553966
      10Locked36.657125621362912711
      11Locked34.3737816235623887566
      12Locked31.9834384677537914143
      13Locked33.3138196564466401
      14Locked37.31432564492273688
      15Locked37.653835783453021715
      16Locked38.6820626548785
      17Locked37.3101142416
      18Locked37.643651622
      19Locked38.63415081118
      20Locked38.650312993
      21Locked38.944804106
      22Locked38.621649700617051
      23Locked38.6348476701423749
      24Locked38.910108093126052
      13659997949512064 qam3
      22360000049512064 qam5
      33010001749512064 qam4
      44310001949512064 qam2
      54960000049512064 qam1
      2ATDMA0010
      3ATDMA0000
      4ATDMA0000
      5ATDMA0000
      • jpeg1's avatar
        jpeg1
        Perhaps VM staff following this will now agree that you need a technician visit to mend this awful connection.
    The poor downstream SNR maybe the reason for seeing
    a massive error rate across all downstream channels.
  • Thanks to everyone who took the trouble to respond to my cry for help with advice and to Alex and especially the VM engineer who resolved it today - It tuns out there was a 4 way splitter where the cable comes into the house in the garage which split the cable to my TV box upstairs and router downstairs - It had gone bad somehow - new one of those and all is perfect again with all SNRs at 37 or higher and 0 Post RS errors, no packet loss etc!
    Thanks All!
    what good now looks like
    13310000003.737256 qam25
    2139000000338256 qam1
    31470000002.938256 qam2
    41550000002.740256 qam3
    51630000002.940256 qam4
    61710000002.938256 qam5
    71790000002.538256 qam6
    81870000002.738256 qam7
    91950000002.940256 qam8
    10203000000340256 qam9
    11211000000338256 qam10
    122190000002.940256 qam11
    132270000002.738256 qam12
    142350000002.538256 qam13
    153070000003.738256 qam22
    163150000003.538256 qam23
    173230000003.737256 qam24
    183390000003.737256 qam26
    193470000003.538256 qam27
    203550000003.538256 qam28
    213630000003.738256 qam29
    223710000003.538256 qam30
    233790000003.538256 qam31
    243870000003.438256 qam32
    1Locked37.6340
    2Locked38.9450
    3Locked38.9380
    4Locked40.3440
    5Locked40.3620
    6Locked38.9630
    7Locked38.9420
    8Locked38.9430
    9Locked40.3450
    10Locked40.3460
    11Locked38.9330
    12Locked40.3240
    13Locked38.9210
    14Locked38.9290
    15Locked38.6180
    16Locked38.6280
    17Locked37.6360
    18Locked37.6140
    19Locked38.6230
    20Locked38.9240
    21Locked38.6180
    22Locked38.9170
    23Locked38.9170
    24Locked38.990
    • David_Bn's avatar
      David_Bn
      Excellent new rich_simpson, and we're pleased to hear that our team have been able to get this one resolved for you.
      Do please come back to us if you experience and further issues, and we'll be happy to help where possible.
      David_Bn
