- TudorVery Insightful Person
It would seem the XGS-PON areas are still ‘under test’, there is no modem mode that a lot of people require. These XGS-PON area not also not totally VM controlled, they are ‘owned’ by another company although VM as a large interest in it and are the currently the only ISP available.
- suttonscloudOn our wavelength
The XGSPON network is owned by Nexfibre, and the FTTP rollout plan is a joint venture with VM and O2 (VMO2).
Virgin Media is the only ISP for Nexfibre at the moment while the network is in 'trial' state.
As Tudor mentioned below, there is no Modem Mode for the Hub5X and VM have confirmed there is no future plans to bring it to the 5X. If you haven't noticed, business customers cannot order a service on XGSPON; i assume this would be due to the lack of flexibility on the Hub5X, most businesses may need to integrate with their own network which currently is not possible as the ONT is built into the Hub5X with very little support.
I wouldn't be surprised if HFC areas get moved to RFoG before XGSPON. If VM moved all their HFC customers to XGSPON it would be a massive cost as you would need a new router, and a engineer visit to bring the fibre into your home. At least with RFoG the work can be done outside of your property, and no need for a new router, everything would stay the same inside of the home.
"At least with RFoG the work can be done outside of your property" small point, but I think it still needs a mains power connection from your premises.
True, think it’s a power injector. Either way, still a lot cheaper than a new router, and especially wouldn’t surprise me if Virgin sent them out with instructions and got the customer to do it with no engineer visit.
more surprisingly, I’m shocked it’s not already built into the Hub5. I’m pretty sure TV providers like sky provide power over the coax straight from the box for the LNBs to work as it’s such low voltage.
- unisoftSuper solver
suttonscloud wrote:The XGSPON network is owned by Nexfibre, and the FTTP rollout plan is a joint venture with VM and O2 (VMO2).
Conversion to RFoG first (with DocSIS 3.1 upstream issues) before XGS-PON LOL. Erm ,nope. Re-contracting and new customers defaulting to XGS-PON once available, yes. The start of this is dependent upon VM's billing and infrastructure provisioning services all talking to each other properly; this has been the hold-up as a number of area either done or being done right now in terms of street infrastructure (like Peterborough).
- Client62Alessandro Volta
RFoG as replacement for HFC ? No No No !
Virgin Media are awash with financial debt, lets not add technical debt to the situation.
The cost of a new VM Hub will be little when you factor in the 2 or 3 engineer visits to the customer premise to pull in a new fibre and get it inside the customers house where it connects to the internal ONT & PSU that are currently being used.
A lot of customer disruption and the outcome is loss of the 3.1 DOCSIS Upstream channels. - IPFreelyRising star
Billing and provisioning finally there. Live customer testing in progress. They remove the coax from omnibox into home and replace omnibox. May dig new drop from pot or use existing one. They reclaim the coax drop.
Given they're at the stage now shouldn't be long and for you will depend on how much they release at once.
Just FYI nothing to do with Nexfibre for now. Nexfibre are new build only, the Mustang build is VMO2 and will be spun off into their wholesale NetCo with the HFC.
- gonnellaOn our wavelength
is this any closer yet?
- Cardiffman282Community elder
I sense the upgrade in Cardiff is imminent and VM network engineers have told me it will be live by April but nothing official yet.
Also no mass, forced customer migration for the foreseeable. Existing customers recontracting will be encouraged to go XGSPON, sale of HFC to new customers will be ceased and that'll be it for years. The networks will run side by side into the 2030s.
- AdduxiVery Insightful Person
VM put in the nice new shiny green boxes beside the older ones in our area around 3 years ago. Since then, nada, nothing. Can't remember the last time I saw any VM working in the area. As for the Hub 5X, I rather have a box of frogs ;-)
They are likely waiting for billing and backend systems to be able to cope with HFC/RFoG and migration to XGS-PON, waiting for any wholesale systems to be working if legacy network is going wholesale, and they may wait till a large chunk of the UK has the new XGS-PON network (Mustang) installed so that live date is extra publicity event.
Looks like VM have started to offer up to GIG2 in some HFC areas that have been upgraded under Project Mustang. The VM checker now states if you can get it when you put your post code into it. I think there may be a caveat where if you have had HFC before to your address it may not show up, but completely new installs requiring engineer visit, will show up. No idea on the reasoning as XGS-PON prices have been the same as HFC unless you want to add on the £6 extra to have symmetric speeds...
David Bouchier from VM gave an industry chat to delegates to 'Connected TV World Summit' in London.
Later this year Virgin will complete the move from QAM broadcast to IP transmission, bringing in small form factor setup boxes, with bookmarking in the cloud replacing hard drives.
Bouchier says the big change will come in the install experience. He said “There is no longer a need to have that cable running around the house if you want more than one set top box. It allows us to be as kind of nimble as the S watts themselves and connect to a TV wherever it is in the home using again a great install experience that we have with Virgin Media where our engineers will ensure that your broadband travels around the home.”
Value for money is also a key factor, offering 30-day contracts, but also much longer periods than has previously been the case. “The longer you stay with us, and the model comes from our mobile business, whether that’s a 12, 24, 36 month contract, that benefit will also drive the content value for money proposition.”
There are also expansions in the overall offer, another mobile operator incentive, adding fitness, books and magazines and technology to extend customer relationships into new core areas.
Still nothing...... network around here is all provisioned and ready
Related Content
- 8 months ago
- 4 months ago
- 9 months ago
