- carl_pearceSuperstar
VM are not likely to remove any of their cabling as you are not a customer.
Remove it yourself as there are no high voltages.
- jpeg1Alessandro Volta
Virginmedia like to keep the cables there in case you or a later resident might want to use them. If they only go to your house and no others, you can remove and bin them yourself. The cables are easy to cut and harmless.
Related Content
- 3 months ago
- 1 year ago
