george1531's avatar
george1531
7 months ago
Old cable & wireless under drive 1997/coax questions
Just a quick few questions
I know a few things about technical stuff, but I haven't posted here so I will try to get a quick reply
The cable that goes under my drive has been laid by cable and wireless 1997 , this cable was then attached again to our house about 2013, broadband only from VM.
I'm not sure what cable was used as it's buried under the drive and just comes straight into the property but I was wanting to know, even though I have not had any problems on a 1 GB connection (1150mbps to router all the time) does this ever need to be repulled as suggested by virgin, the offer has been made and I declined it.
Is it a simple case of "if you don't have any problems you don't need to fix it" or is it a case of the cable is nearly 30 years old so it needs to be changed regardless. It has never been disturbed by anyone.
I have Broadband only I always use modem mode and have my own wireless setup but this is more a question about how virgin deal with things.
I have had the isolation box replaced recently because the old one was , well old., basically and also the attenuator was changed to one that looks like an inline one compared to the old one that was a bit bigger... is there really any difference... it is the correct wideband one (why did another vm tech put forward path one before?)
I just want to know other new ones better attenuator wise?
Main question here is the internal cable that comes from the wall to the super Hub has now been changed from rg59 to RG6 and I have bent it a little bit without even thinking
I just want to know if this is okay also
should I be concerned about the cable outside if there is no problems or should I just forget about it
I have to admit all of my power levels and speeds are 100% fine?
Black cable is new RGB6, old is white RG59. Length is 2metres to hub.
  • asim18's avatar
    asim18
    7 months ago
    They both perform the same basic function. Both types of attenuator will attenuate the forward path as well as the return path. It's just that the newer ones aren't labelled as "forward path" but it is still technically a forward path attenuator because the return attenuation does not vary and stays consistent whether you're using a 3db attenuator or a 20db attenuator. (this is confirmed in the datasheet on the technetix product pages for both attenuators).
    The only difference between the newer one and the old one are bandwidth tolerances. The newer ones can tolerate much higher frequencies.
