on 08-03-2024 21:29
After a month of interrupted wifi and internet, we finally have had an engineer out to sort out external cabling and he also supplied a new hub 5 (after 1st replacement hub didnt work properly either) Our problem is now the white pod will not pair, just flashes white. After contacting customer service (who are basically useless) pushing wps button etc we are no further down the line, any help from you guys would be much appreciated, thanks
Answered! Go to Answer
08-03-2024 21:31 - edited 08-03-2024 21:31
VM need to ensure your new HUB is associated to your account, and the old one is removed, so the pod will pair correctly.
on 11-03-2024 17:22
Hi simon1050,
We're sorry to hear you're having an issue with your WiFi pod. This is something we can certainly check for you but in order to do that I will need to confirm some information with you to pass security.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
on 16-03-2024 08:57
Hi Thanks for your reply, we are now in the middle of changing our package so will give VM a few days to sort it out
on 19-03-2024 11:29
Hi simon1050,
Thanks for coming back and updating me via private message too.
It's a pretty simple thing to get done and takes less than 2 minutes this side but there are some teams who won't have access to the system. If once the package change is done, you're still having issues, pop back to me via private message with the information I asked for and I can get that sorted right away for you 😊
Many thanks,
