Palm771's avatar
Palm771
slow wifi
im only getting around 30mbps on wifi, I do the test right next to the router.
1 Reply
    Not getting, your device is drawing data at 30Mb/s.
    This is typical for a device connected on the 2.4MHz band where speeds up to 50Mb/s are typical.
    Check the specifications for the device to see if it is capable connecting on the faster 5GHz band.
