Wifi pod pulsing
Cab0323
My three wifi pods have all of a sudden started pulsing white (no connection). They have been fine for weeks.
Hub 5 was installed a few weeks ago. Tech support reconnected them after they wouldn’t connect automatically after the Hub 3 was replaced.
simple reboot has not worked. There is no issue with distance to the Hub.
Any ideas? Thanks.
1 REPLY 1
Lee_R
Hi @Cab0323 thanks for posting and welcome to our community.
Sorry to hear your pods aren't working for you. And sorry for any inconvenience this may be causing your household. I would like to take a look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
