22-04-2024 20:44 - edited 22-04-2024 20:47
I have two wifi pods and one hub
My mobile does not easily switch from one to another. If I am in living room connected to Hub 3.0 and then moves to bedroom where I have wifi pod, I expect mobile to connect to wifi pod. But it stays connected with downstairs Hub with almost no wifi strength despite to having wifi pod plugged-in next to my bed. I have to switch off my mobile's wifi and switch it back on then it works sometimes.
Same happens other way around and also with kitchen wifi. As a result most of time, I and my family are on low Internet speed despite of having a super speed hub in living room. Wifi pod did not solve my low speed problem but it made it worse.
Please help
I talked to virgin media few months back but no luck. I asked to replace many years old hub3.0 when my contract was renewed but they denied to do it unless I opt for a higher package.
on 23-04-2024 07:13
Toggle the phone's Wi-Fi Off / On, to encourage it reconnect to a stronger signal.
on 25-04-2024 13:49
Hi there @avtarjain
Typically a phone will stay connected to the WiFi network is was connected to unless this network drops completely, have you been able to try toggling the WiFi as suggested by our community member Client62?
on 25-04-2024 14:41
AFAIK, the ability to roam seamlessly between Wifi beacons, is governed by the device, not the (in this case) VM Pods.
on 26-04-2024 08:00
Hi thanks all for response.
Regarding the solution of switching WiFi on and off, does not sound like an intelligent solution. To answer the question, yes it would switch connection device and can be seen as a last resort solution.
It is not practical for me and family to switch their WiFi on and off every now and then as we move between rooms, kitchen and toilet whole day. Does it not sound funny.
Mobiles and Laptops currently stay connected to its signal sender regardless of wifi strength. Even if WiFi drops to 1mbps, mobile does not switch to strong signal in same room.
on 26-04-2024 08:02
Do you know how to setup device to roam seamlessly
on 26-04-2024 14:07
Its the device that does this as far as I know. There is nothing to configure I believe, my iOS phone for example, will move from AP to AP as I walk about the house.
27-04-2024 07:21 - edited 27-04-2024 07:21
Firstly I am on android so it might be a difference and Second I suspect when you move you loose signals from 1st device all together. In my case I still get 1 or 2 mbps signals which does not let phone to switch to different pod.
As per google, There are 3rd party apps which do wifi switching automatically but you have to tell them what strength is minimum threshold for switching. I can't find any app yet in play store. Bit scared of downloading any dodgy app.
