on 22-04-2024 17:10
Hi,using virgins connect app on my Android 13 phone to check the WiFi speed from the hub I get 15-18 mb download speed with the phone about 1metre away from the hub,same result in the next bedroom,in the lounge where the WiFi pod is plugged in I get a speed of 28-35 mb.
My devices that use WiFi are a mobile phone and Amazon Firestick
That speed seems very low , especially in the room where the hub is? Is the hub faulty ?
on 22-04-2024 17:20
Assuming the speed to the Hub is OK as that is not mentioned as a concern.
These look like speeds from a device connected on the 2.4GHz band. Can your phone use 5GHz Wi-Fi ?
When testing near the Hub make sure the mobile phone has reconnected to the Hub i.e. the Wi-Fi signal is at 100%,
if the mobile hangs onto the signal from a more distant VM Pod that would reduce the result from a speed test.
on 22-04-2024 17:32
Hi thanks,
Yes the phone only receives on the 2.4 GHz band and the Firestick the 5 GHz band
Yeah the phones WiFi icon is 100% full when in that room near the hub and using the VM app for a WiFi speed test.
Broadband speed comes up at 365 mb on a 350 mb connection.
on 24-04-2024 17:59
Thanks for coming back to us @Moogera,
Do you have any devices that are located close to the hub that can be connected via an Ethernet cable?
This can help lessen the traffic on a Wi-Fi connection and thus make the overall experience for Wi-Fi only devices - such as mobile phones and tablets much smoother.
David_Bn
on 25-04-2024 13:18
The only 2 devices I have using WiFi is the Firestick and my Phone
The hubs connected via cable to the PC
on 28-04-2024 12:07
on 28-04-2024 20:09
We have one Samsung A13 mobile running Android 13 it is a 2.4GHz Wi-Fi only device. Turning OFF Bluetooth significantly increases the results from a Wi-Fi speed test i.e. it is back to normal at 55-60Mb/s. Might be worth a try.
on 01-05-2024 20:46
Thanks,my Bluetooth isn't turned on probably ever
on 04-05-2024 09:11
Thanks for confirming Moogera,
So I can get a few more details from you I've popped you over a private message.
Alex_Rm
