Katie_F
1 year agoJoining in
WiFi pod shows fair connection
I received a new WiFi pod (the second one added to my set up). This pod only shows a 'fair' connection. Ive moved it to a socket next to the router to test it in close proximity but it still only remains fair. The first pod shows a great connection so don't think it's likely to be related to the routers connectivity. Is it just a duff pod? Should I pursue a replacement or is this a known issue that can be resolved (obviously I initially wondered about distance from the hub, but since it's now plugged in about 30cm from the hub without resolution this would suggest this isn't the issue).
