Carlislepete's avatar
Carlislepete
WiFi pod not connecting
I recently received a WiFi pod but it will not connect and is not showing on the connect app I have the hub5 and have tried resetting the router. I have tried to connect it in the same room but it just keeps flashing blue.
  • Same situation here today, just received a white WiFi pod and trying to connect it to a Hub 5, plugged it into a socket in the same room as the hub and it's just doing the cycle of flashing green then flashing blue for 10 minutes. Channel Optimization is enabled on the hub (saw this as a possible fix on another thread).
    Hub 5 hardware version is 1.1, software version is LG-RDK_6.9.35-2302.6.
    • jbrennand's avatar
      It may not be "activated" on your account.
      Call the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
    • Carlislepete's avatar
      Carlislepete
      Mine is still not working even after trying the 60 second reset 🤷‍♂️
  • Zach_R's avatar
    Zach_R
    Hi Carlislepete,
    I'm so sorry to hear that you're having some issues connecting your Wi-Fi Pod recently. Is this issue ongoing for you today? If so, is it still displaying a flashing blue LED?
      Carlislepete
      Hi yes I am still having issues the pod will flash green for a few minutes then will flash blue.
      • Carley_S's avatar
        Carley_S
        Sorry to hear this is still not working for you Carlislepete
        Please ensure that the pod is in a mains socket (not in an extension) as close to the router as possible.
        I recommend to try a 60 second pin hole reset on the router. This will revert any customisations back to factory settings and full update the router with firmware/software updates. Please do not reboot the router whilst it is completing the pin hole request.
        The pod should flash for 15 minutes whilst communicating to the router and then stop flashing when it's ready to be positioned in the home to boost the coverage further.
  • I'm having the same problem. Eventually received my 1st pod, but it will not connect to the hub and is not showing in the connect app. I've tried all the fixes in the threads on here.
    Any help would be appreciated.
    • Steven_L's avatar
      Steven_L
      Hey paulc1664,
      Welcome back to the community and thanks for taking the time to post.
      I’m sorry to hear of the issues that you’re having with your WiFi pod at the moment, I would be happy to take a further look into this for you but first I would need to confirm a few details via private message, please look out for my message and we can get started.
      Kind Regards,
      Steven_L
    • Steven_L's avatar
      Steven_L
      Thanks paulc1664, I have reconfigured your hub and pod now, so that if you plug the pod in now, it should recognise your hub and start to connect.
      Please let me know if this hasn't worked.
      Kind Regards,
      Steven_L
      • Gordy3's avatar
        Gordy3
        Steven
        Any chance you could assist with a similar issue.  Tried all suggested fixes on here and the new white wifi pod will not connect to the Hub 3.  Can see it it on the VM Connect app but then get a message stating activation failed and you have to reboot the pod again to see it in the app. Does the same thing repeatedly.  Existing white pod works fine.
