on 28-01-2024 16:51
I have the connect app and it will not recognise the pod. It just slowly blinks a white light. I have left if sitting next to my hub4 for over 24 hours, as some have suggested, and it has not connected. I have reset my hub4 back to factory settings also with no joy.
Any suggestions would be appreciated
Answered! Go to Answer
on 28-01-2024 16:54
If its a new Pod, it may not have bee associated/activated onto ypur account yet.
First, call the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number - see if they can sort it for you
on 28-01-2024 16:54
on 29-01-2024 12:41
I used the number and the Pod was not registered. It now has.
Thank for your help
