2 weeks ago
My wi fi keeps dropping so downloaded virgin connect app to check signal and if booster required. App can’t find my hub even though connected to wi fi and now it’s dropped again. Any idea how to fix
2 weeks ago
Hi Scotty6964,
Thank you for reaching out to us in our community and welcome back, it has been a while, we hope you have kept well, sorry to see your WiFi connection is dropping and that our Connect App ins't seeing your router, I was able able to locate you on our system with the details we have for you and it looks like you have spoken to us.
Paul.
2 weeks ago
I have received the pod plugged it in but the app is not able to find hub still
2 weeks ago
Well pod plugged in and virgin connect app still cant find hub etc
a week ago
Morning @Scotty6964
Have you got a VPN on your device? Normally this is what that error message means on the app.
There are a few requirements for the Pods to work with our Hubs:
• The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
• Channel Optimisation must be left on.
• The SSIDs must be the same and broadcast enabled.
• The SSID must be password protected.
• The Passphrases of the SSIDs must match.
As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
